Potential Hardcore DIY Question
.....does removing the cam boxes necessitate a valve adjustment?
Do you mean the chain boxes, or the camshaft housing fromt he heads?
In either case, yes, you will be doing a valve adjustment, not to mention re-timing the cams. AFJuvat |
The camshaft housing from the heads.
Thanks for your reply! |
| All times are GMT -8. The time now is 01:24 AM. |
