Speedometer quit
Walked into the kitchen today and saw a hornet on my window.
Guess if they woke up it's time for the 911..so...had to make a run down the street and took the 73....Ahhh........felt good..... But, my speedo quit...Any ideas? Worked fine last year. |
Speedo or Odo?
odo been out for years.
Speedo just now out |
Pull the speedo from the dash and see if the cable is connected. If it isn't, there's your problem. If it is connected, disconnect it. Go for a drive and see if the cable turns. If it does, your speedo is bad. If it doesn't, check the boss on the tranny to see if the cable is attached.
| All times are GMT -8. The time now is 02:50 PM. |
