Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Question Smugglers box ???
Can someone tell me about the smugglers box and the covered tube thing in the bottom of my 1974 911. I can't find any information on this.
Old 04-08-2004, 02:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
rickeolis's Avatar
Porsche Crest
They're originally designed to house the Kerosene filled heaters installed on the very early models as an option. The tube simply connects into the cabin as a heater vent.
Later models have the air conditioing units installed in there too.
I've epoxied a plastic panel guarding my steering column and keep oil and brake fluid in there...
-Rickeolis-
1986 Corvette
Old 04-08-2004, 03:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
bigrubberjeep's Avatar
Sounds interesting, any pictures?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 04-08-2004, 03:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Bill Verburg's Avatar
The smugglers box is in the trunk. Just lift up the carpet, you can't miss it.
The Smugglers box according to the true Porsche historians was originally intended to house the battery. It was only after the meager heat from the original heater boxes was found to be inadequate in the prototypes that the gas fired heaters were installed there and the batteries moved further forward. I don't believe that there were any Diesel fired heaters, but I could be wrong.
Bill Verburg
Old 04-08-2004, 03:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Oh that one! Ok now I know, thanks!
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 04-08-2004, 03:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Never left, but not right
Zeke's Avatar
Old 04-08-2004, 04:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
Gon fix it with me hammer
svandamme's Avatar
do you mean your spare fluid , or did you actually move your brake fluid reservoir there?
Stijn Vandamme
EX911STARGA73EX92477EX94484EX944S88NOW987C2007
Old 04-08-2004, 04:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
ttweed's Avatar
The early SWB ('64-'68) cars do have the brake fluid reservoir located in the smuggler's box from the factory.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-08-2004, 04:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I use that box for mucho small parts in those plastic boxes you always see in food stores.. I wrap it in old wetsuit parts.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-08-2004, 05:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
I have a '68 and my brake fluid resevoir is up on the side of the trunk sort of next to where the gas fill cap is.
I have a blower in my smuggler's box, but I don't think its a gas-fired anything... I just thought it was a two-speed blower to help move more air into the car?
Now I'm confused...
1968 911L
2004 Dodge Dakota SLT Plus
Old 04-08-2004, 05:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Usually the fresh air blower is behind the dash, and either the A/C blower or heater is in the smuggler's box.
Maybe your 2 spd fan is from aftermarket A/C or was for something else at some point. Since your car is 36 years old (probably almost 37) who knows what could have been added over the years.
Old 04-08-2004, 05:44 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Shouldn't it be used for actually "smuggling" something! I use mine for transportation of Cuban cigars.
Old 04-08-2004, 06:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
993.986.'s Avatar
Cuban cigars?? Where were you coming (driving) from? Mexico? My brother-in-law coming from Central America just swapped the cigar bands and put them in a different box.
Lester
87 Carrera Targa
03 S430 4-Matic
07 Escalade
96 993 Coupe - sold
Old 04-08-2004, 06:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Grady Clay's Avatar
dotorg,
You are right on all counts.
All 68s had the dual master cylinder brake fluid reservoir up near the fuel inlet.
A 68L had a fresh air blower in there as standard and the gas heater was optional. That was the first powered fresh air as the 65-68 relied on ram air from the vent at the rear of the hood. The only exception was if the 911 has the gas heater, you could just use the blower and not the heat.
In 69 Porsche added the dual outlet fresh air fan behind the dash.
I think I still have a blower retrofit spare part kit that I never installed in my 68 911. It would add weight.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-08-2004, 07:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Insert Tag Line HERE.....
rattlsnak's Avatar
>>The early SWB ('64-'68) cars do have the brake fluid reservoir located in the smuggler's box from the factory.<<
My '66 is also near the fuel filler lid, same as my '72.
Marc
Old 04-08-2004, 07:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
araine901's Avatar
My '66 came with a gasoline powered heater in this location. I removed it. I just wasnt comfortable with a gas combustion divice 4" from my gas tank. I do have my resivor for master cylinder and have since added my fuel pump Canister filter and pressure regulator. I used the old out line from the tank to the heater as my excess pressure bleed back to the tank. Works great and I moved 11 lbs from the engine compartment to the front. (allways a good thing on this car)
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 04-08-2004, 11:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Paul Franssen's Avatar
I recently opened up my "smugglers' box" on my 1988 Carrera, and (from memory) there's some cylindrical thing there, all covered with what looks like some hardened black goo (at first I thought it was spilled out of the cylinder, but it looks more like Porsche sprayed it on). What is in there??? (it shows how much I know!) BTW, this thread set me to thinking that, yes, it is extra space for some small "must carry" items, I'll check how big the available space actually is and find something or other to put in there!.
Belgik
1988 Carrera 3.2L
Old 04-09-2004, 02:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
ttweed's Avatar
Yes, Grady, my mistake in saying "all SWB cars". Checking my factory manuals, I see the dual circuit MC was introduced in the 1968 model, not 1969 as I thought, so the last of the SWB cars had them.
Many of the early cars have been updated to the dual circuit system also, over the years, as their master cylinders wore out and were replaced, so they have had the dual circuit reservoir relocated to the fender, as that is where the bracket fits that comes with the newer, cube-shaped reservoir. I am sure that is why rattlsnak's '66 has a fender mounted one, as the early cylindrical reservoir bottle for the single circuit MC was mounted in the smuggler's box. I did that exact operation on my '66 when I had it. It is a good safety upgrade, as it separates the front and rear brake circuits so (hopefully) if one fails, the car can still be stopped.
TT
Tom Tweed
R Gruppe #232
Old 04-09-2004, 08:09 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Paul,
Your '88 would have the A/C evaporator and blower in there if it came with A/C. If your car doesn't have AC' then I don't know what would be in there.
Old 04-09-2004, 11:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
araine901's Avatar
Paul
Mine had a cylindrical vent for the heater. I would imagine that on cars where the vent was not used the factory sealed them up. I used fiberglass and resin to cover it up and coated it with ruberized undercoating. I was gettin water comming in during the El Ninio rains a few years back. This helped.
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 04-09-2004, 12:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
