sundaypunch's Avatar
ATE Super Blue available in Michigan?
Well, I went through my two cans from Pelican bleeding my upgraded system. I need another can but would like to avoid the 1-week shipping time from CA and get this thing knocked out ASAP. Does anyone know a local Michigan source where I could buy the stuff? Grand Rapids / Lansing / Ann Arbor would be best.
Thanks in advance.
Old 04-08-2004, 07:50 AM
mudman's Avatar
Sorry, I only know of shops on the East side of MI.
-Jeremy
'73 911 and other cool stuff
Old 04-08-2004, 07:56 AM
Irrationally exuberant
ChrisBennet's Avatar
If your braking system isn't on the hairy edge (overheating at the track) I'd recommend just getting some Castrol Synpower. Boiling point is 508 (?) vs 536 degrees for ATE. I started using it on the track last year. Works great and is available at Pep Boys.
-Chris
Edit: It's Valvoline SynPower, not Castrol
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-08-2004, 08:11 AM
The Blue ATE is still available from different sites. I started using Motul's after suggestion from my shop and haven't been dissapointed.
Old 04-08-2004, 09:39 AM
KTL KTL is online now
Schleprock
KTL's Avatar
-Chris
I think you mean Valvoline SynPower, right Chris?
I switched to that (i'm not an avid racer anyway) since I was tired of wasting all the nice ATE Blue stuff.
Pep BoyZ rocks. Sometimes.
Kevin L
'86 Carrera "Larry"
Old 04-08-2004, 09:44 AM
Oh yeah, you're right. Just had a Senior Moment there. Thanks.
-Chris
Old 04-08-2004, 10:50 AM
vash's Avatar
i have to admit, i got caught up in all the pretty blue colors. next time i am going with valvoline...the only real bonus is the blue lets you have positive proof that you are at the new stuff.
poof! gone
Old 04-08-2004, 11:12 AM
Bill Verburg's Avatar
Sherwood has put together a nice little summary of the properties of some different brake fluid, look here for that info
The ATE amber and blue are the same stuff, the blue just has a dye in it and has been banned by DOT. They insist that all brake fluid be the same color for safety reasons. Bottom line, get it while you can.
I am sure that you can dye your own fluid with what I don't know. As Unfixed has pointed out the utility of the blue is in positive indication that the fluid has been refreshed. You all do it at least biannually, right?
Bill Verburg
Old 04-08-2004, 11:40 AM
I know S & G parts in Berkley carries the stuff. They had a store in Ann Arbor when I lived there in 1996.
Jim Chatfield
1972 911T
1999 Lexus RX300
Old 04-08-2004, 12:09 PM
Metal Guru
911nut's Avatar
S-G Import Auto Parts carries it (jchat, I saw it in the Berkley store too!)
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Gon fix it with me hammer
svandamme's Avatar
how many liters goes in the 911 brake lines?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-08-2004, 12:17 PM
Thanks for the leads. As for the amount of fluid, one liter was more than enough for a dry fill and a couple rounds of bleeding. For a fluid swap one liter should be fine.
Old 04-08-2004, 03:13 PM
mudman's Avatar
Oh duh, yes there is a S&G right on Dixie in Waterford too.
Old 04-08-2004, 03:15 PM
IROC's Avatar
One liter is plenty to replace the fluid in the entire 911 braking system.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-08-2004, 03:49 PM
svandamme's Avatar
ok , now i'm confused, if a can is one liter
and one liter is all it takes
then how come sunday punch needed 2 and is still looking for more?
no offence there, i just don't get it, trying to understand, because i have a PP shipment en route with a can of the blue stuff....
Stijn Vandamme
Old 04-08-2004, 07:02 PM
1 liter should be enough but having more on hand won't hurt.
When you flush your brakes you don't take all the old fluid out first. The new fluid will push the old fluid out but it will also mix some with it too. In practice you'll bleed fluid out of the caliper until it looks good and blue.
When I used to use ATE blue my practice was to flush my brakes in the spring with inexpensive brake fluid (but rated correctly) and then replace it with Blue just before my first track event.
In your case I would recommend flushing out the old fluid with some locally available brake fluid until it comes out nice an clearn and then switch to Blue.
-Chris
Old 04-09-2004, 03:47 AM
svandamme's Avatar
thx chris,
i'm replacing my brake lines at the same time so flushing isn't going to be such an issue
Stijn Vandamme
Old 04-09-2004, 04:00 AM
mudman's Avatar
No, but you'll be doing lots of bleeding passes to get the air out of the new lines and seepage out of the unreplaced lines. I would still start with an auto parts store fluid and then do Blue after fully bled. The castrol stuff isn't very expensive. Also, that is just more fluid passing through the lines and hopefully clearing out more debris particles.
-Jeremy
Old 04-09-2004, 04:11 AM
svandamme's Avatar
allrighty , gonna make them lines bleed like freshly slaughtered hog !!
Stijn Vandamme
Old 04-09-2004, 04:14 AM
mudman's Avatar
Remember to dispose of your fluids properly!
Old 04-09-2004, 04:16 AM
