aways's Avatar
driver's side door cabin light switch...
The cabin light does not come on when I open the driver's door,
but it works fine when the passenger's side door is opened.
I removed the little push button switch from the driver's side
door jamb, and discovered that there was no wire attached to it!
I guess it must have come off somehow. Is there any way to
retreive this wire, or put in a new one without taking the front
left fender off??? Please help!
commandant of the compound
Old 07-25-2004, 09:28 AM
david914's Avatar
Look for a brown wire w/white stripe behind the switch. You won't have to take the fender off. You may have to remove the kick panel cover to get access to behind the switch if you can't fish it back out through the switch hole though.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 07-25-2004, 09:40 AM
You can look for brow-white wire and conect to door switch
Old 07-25-2004, 09:41 AM
aways's Avatar
Thanks David and Diana. I looked for the brown/white stripe wire,
and think I found it. The problem is that I can't access the area
behind the switch. I removed what I think is the "kick panel",
which is a carpeted panel on the left side under the dash, but there
is still a barrier where the brown/white wire passes through that
I can't remove. How can I access the area behind the light switch
button without removing the left fron fender? I hope someone has
a suggestion. Electrical problems can be the pitts!
Old 07-25-2004, 09:16 PM
