-   -   Need help setting up a 915 for short gears (http://forums.pelicanparts.com/porsche-911-technical-forum/157949-need-help-setting-up-915-short-gears.html)
edbaus 04-11-2004 12:18 PM
Hi,
What is the best way to select gears. Is there an online guide.
I have a 74 915 that I use with my race 2.7 L in a gt4 car.
Here are my current stock gears.
11-35
18-33
23-29
27-25
21-29
What is a good source for new/used gears also.
I currently hit the shift light (set at 6800) at the end of the back straight on Mid-ohio in fourth gear. I never use 5th gear right now.
By my calculations (and assuming I am going to leave 1 & 2 alone) My new gears should be:
11-35
18-33
22-30
25-26
28-23
This is about a .75 drop between all gears instead of the larger .68 step between second and third.
What should I be looking at on my dyno sheet to lead me to a new gear range.
Looking at my dyno sheets. I see that my max torque comes in at 4900 and my max hp comes in at 6500. Should I be tailoring my gearing to take advantage of max torque or hp.
Ed
304065 04-12-2004 06:24 AM
Dear Ed,
Fine questions all, you might try moving this to the Racing Forum.
Bill Verburg 04-12-2004 06:40 AM
I posted this over on Rennlist but might as well do so here as well
You want to gear for the hp curve
here is a summary of what you have, what you propose, and another idea. The question becomes what top speed do you need to gear for? Any idea?
http://forums.pelicanparts.com/uploa...1081777230.jpg
