weber problem
If I activate the fuel pump in my car the center barrel of the left bank webber will drip fuel. its coming right from the center of the barrel through the emulshion tube. its not pouring out or anything just a steady drip. none of the other barrels do this.
any ideas? float level off?? Thanks, Kyle |
The float level setting is most likely off. You can make gross adjustments to the float itself (inside) and minor adjustments by changing shim thickness under the needle valve (externally). Check for proper level using the plastic float level tube that attaches to the outside of the float level drain plug (may be available through PParts and/or PMO).
Fuel shouldn't begin "dripping" from the discharge tube until well after idle. Sherwood |
I Draned out the float and got some dirt so i ran the fuel pump with the bolt out and got a little more dirt.
its not doing it any more seems to be fixed. Thanks, Kyle |
| All times are GMT -8. The time now is 04:57 PM. |
