-   -   H1 Install--Finally--need a little help (http://forums.pelicanparts.com/porsche-911-technical-forum/157999-h1-install-finally-need-little-help.html)
JonT 04-11-2004 06:26 PM
H1 Install--Finally--need a little help (Pics Too!)
I'm finally installing these 1 year after purchasing them and getting the chrome redone and figuring out how to put them back together. I just removed the old SC headlight and there were 4 or so little screws that held the old headlight assembly inside the fender hole opening. As I'm looking at this H1 light, I only see one screw that will hold this light in place after I plug in the light assembly--is this correct?!
jdowty3 04-11-2004 06:46 PM
One screw at the bottom is correct. The top should seat over a small tab which keeps it in place. The bottom screw is either a finish screw if your just using the chrome ring or a special screw that a finish screw will thread in to if your using the cover rings.
JonT 04-11-2004 07:04 PM
Here's a coupla pics--I couldn't wait so I just set them in and took a couple. I can't believe there is only one screw that holds these in!http://forums.pelicanparts.com/uploa...1081735360.jpg http://forums.pelicanparts.com/uploa...1081735376.jpg http://forums.pelicanparts.com/uploa...1081735390.jpg http://forums.pelicanparts.com/uploa...1081735406.jpg
