Help with engine clatter
My 87 Carrera started having a clatter at mild load between 2800-3500, this caltter did not vary with rpm and was at a frequency of the cold idle lope that I also have. It then sudddenly turned into a a very bad pinging at any RPM. (I limped the car home at below 2000 rpm and at time it would sound like a cummins diesel). My plan currently is to pull the valve covers off and have look. I thought the sound was coming from the drivers side, but when I opened the deck lid it was not as direct as from the drivers seat. Oil pressure is OK, no loss of oil or burning, engine has 100000 miles. Any help would be greatly appreciated.
Thanks,
Arnie
Old 04-20-2003, 09:28 AM
ted ted is offline
likes to left foot brake.
ted's Avatar
chain tensioner?
Old 04-20-2003, 09:45 AM
PRO Motorsports
Tyson Schmidt's Avatar
Did it sound like pulling a chain out of a metal garbage can? If so, then its a dead chain tensioner. Probably the case.
If you don't find anything when you pull the cam covers, you should pull the muffler and remove the chain housing covers to inspect the chain tensioners. Even the pressure fed tensioners can go bad, though far less common.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-20-2003, 09:49 AM
lateapex911's Avatar
I had a failure in thechain tensioner world....it sounded like an extension ladder collapsing. The it stopped running. Something to do with six bent valves. Be very careful.
Ignition settings?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-20-2003, 10:04 AM
Senior Member
Doug Zielke's Avatar
Broken head stud!
Pull the valve covers.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-20-2003, 10:09 AM
Thanks to all, I hope it is just something simple. I'll pull the cam covers tomorrow and go from there.
Thanks again,
Arnie
I'll keep all informed
Old 04-20-2003, 05:05 PM
Pulled valve covers and did a quick check of the valve adjust, didn't have the proper gap gauge, but only #2 felt a bit loose than the rest. Nothing obvious was broken. Pulled the left timing chain cover, all was fine, couldn't get the right cover off, oil coller line interference. Is there an easy way of getting this off? Any other sugestions are welcome.
Thanks,
Arnie
Old 04-21-2003, 06:08 PM
Porsche Head's Avatar
Did you ever get this resolved? I have a 72 911e, but the car I am having very similar problem with is a 90 VW GLI 16V.
Yo me it sounds like definitie detonation but even off load like reving it up in N ut won't do it for a minute tilll it warms up.
I can't even drive it to unload/fix it at the shop!
Cliff
1972 911E w/3.0 RS Replica
1988 M5 300hp
2016 Audi Q5 TDI
Old 04-09-2004, 04:36 PM
Cliff,
Yes I finally resolved the issue. It was a spun bearing and broken crank. (rebuilt the motor with the help of Wanye's book and Walt Watson) I'm not sure if yours is the same. I would drain the oil and look for particles in the oil to see if it is a bad bearing.
Good luck,
Arnie
Old 04-11-2004, 08:10 AM
Cymru am Byth
carmad's Avatar
I had the same scenario, spun rod bearing no3 which seems to be the first to go if there are any oiling issues. Rebuild is almost complete.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 04-11-2004, 08:23 AM
Thanks guys...I'll check the oil this weekend, I thought it was too severe for pinging, I mena the thing won't even run in 1st.
Thanks,
Cliff
1988 M5 300hp
2016 Audi Q5 TDI
Old 04-12-2004, 12:44 AM
