Boge Strut installation
Thanks everyone that helped me earlier with the strut choice.
Just wondering if there is anything I should definetly order besides just the struts. Any certain washers, lock nuts etc. that I will most likely need when I start replacing the struts. Thanks, David |
Unconstitutional Patriot
How do your rubber brake lines look?
Tie rod ends and boots? You don't need any other fasteners. You do need a new split pin for the tie rod end nut. 8mm allen socket for the bottom bottom cover. Jürgen |
