911 sc 3.0
I just bought a 78 911sc. 3.0
Are there any problems with the 3.0's and are there any valve adjustments or things that need checked routinely? |
Try the search function against "head studs", "pop off valve", "rubber centered clutch", "chain tensioner". That should keep you pretty busy reading for a while. Let's see a PIC of your car.
John Adams 1980 ROW 911SC |
How do you attach an image. I am not signed up for any image host
click on post reply button and at the bottom of the screen there is an attach multiple button, click on that and then use the browse button to attach your picture file.
Looks good, congratulations! Looks like it's time to get the garage cleaned out for the SC.
Thanks, for the compliment. That is the previous owners house. My garage is clean.. I need to find a whale tail. I've been watching E-Gay.
Check the Pelican classifieds. I found mine here and it was a local pickup too.
Welcome to the SCWDP. Nice looking car. If you have a Cat and your local regs will allow, replace it with a test pipe (or put it back on when testing time is near). Redline comes much faster with out the Cat.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
they do not do any sniff testing here but they do require cats to be in place. All they do is look. I have been deined a motor vehicle inspection sticker before cause I had removed a cat. I took the one off of my truck, gutted it and bolted the empty shell back on.. it passes. I have been watching the classifieds here for a while. I have to sell my 944 now. Maybe I will post it here.
Go Speedracer, go!
A euro premuffler will gain you more than a cat, and it looks like a cat. If you put heat shield around it, I doubt any inspectors could tell the difference.
1981 SC ROW Coupe |
nice car! i am mulling over selling my tail. i will keep you in mind. wondering how to box up a fiberglass tail? that is one hell of a box!
poof! gone |
which tail do you have?? I am looking for the 930 turbo style.
tails for sale in the classified section
FS 7x16" Fuchs pair and Turbo Tail TURBO TAIL (white) Factory 930 Turbo Tail
CIS can be a little finicky. If it begins to run rough it will most lokely be the injectors. CIS. You might have to bleed the fuel system. Easy to do. Costs nothing. I would get the P-shop manuals $$$ if not then the Bentley would be a good second. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_documt_pg3.htm Whatever you spend on a manual will be returned in savings. If this is your first Porsche learn the heater/defroster controls. It sucks to be in traffic and trying to read that little sticker on your glove box door. Valves? Cheap if you can DIY. Enjoy! great looking car. On the tail my buddy bought a guards red tail and you can't tell it's from a different car.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
