no spark
Monday morning blues:
85 Carrera 3.2 Started the car this morning ran perfect, as usual. Pulled to a gas station, turn off car (which I usually don't do). Filled up, went to start the car again and it only cranks. Checked for spark; no spark. Checked for fuel; although I didn't put a guage to it there was pressure in the line. I reconnected the fuel plug, cranked it again, loosened plug again and there was pressure. About a month ago I put a new DME relay and Head temp sensor because the car was hunting when hot at idle. Any other suggestions? |
Re: no spark
This will probably be moved shortly but,
http://www.pelicanparts.com/techarticles/911_carrera_start_troubleshoot/911_carrera_start_troubleshoot.htm |
