-   -   Head Temp Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/158222-head-temp-sensor.html)
Max911SC 04-13-2004 05:35 AM
Head Temp Sensor
During the rebuild I cut the wire to remove the head temperture sensor. What tool do I need to replace it and can I find it at a parts store?
Wil Ferch 04-13-2004 10:13 AM
Usually a 13 or 14 mm (?) deep socket...with a slot to allow the wire to pass through...but you already cut the wire. Archives suggest that the sensor used two different hex sizes...at least for the early and later 3.2's as you go from OEM to later style replacement. Can anyone confirm?
---Wil Ferch
NoLift911 04-13-2004 10:41 AM
I used a 14mm tall socket on my 84 Carrera. I sacrificed the socket to the Dremel gods for the slot.
-Jeff
nolift911@hotmail.com
