clutch parts question
new parts are here, yea, but rubber centered clutch was sent instead of spring centered, doesn't require updated quide tube, but is it worth the trouble to send it back and get spring centered, if so, is the pressure plate same no matter so doesn't need to go back?
Mike B.
Gilbert, Az
89 911 Coupe
Old 04-13-2004, 09:58 PM
chrisp's Avatar
I would send it back for two reasons:
1.) Doesn't sound like it's what you ordered
2.) Rubber center clutches are likely to fail based on time, not use. You want a clutch that wears out because you've used it not because it "x" number of years old.
I think the PP is the same but you may want to look into it.
'83 SC
Old 04-14-2004, 05:15 AM
Rick Lee's Avatar
PP is the same, assuming it's the OEM Sachs kit. Disc may also be specified as that of a '77 930.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-14-2004, 05:37 AM
