Stuck Convertible top
I accidently tried to close my 90-911 top with the boot on and now it won't go back up? How do I get it back up? Is there some type of reset button or something?
Jeff--
Old 04-13-2004, 11:53 PM
DJB DJB is offline
DJB's Avatar
BE VERY CAREFUL
I would suggest you raise the top manually. If it is similar to the earlier models your cables may have come loose from the motor, and you may twist your top and SNAP your supports (ask me how I know).
Raise it manually and check it carefully - there are a number of topics if you do a search.
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 04-14-2004, 12:49 AM
Once I raise it up. Should it work electronically after that? After manually putting up?
Old 04-14-2004, 08:48 AM
