Is there anything I can do to clean up the threads on the expose male side?
It is not an alignment issue. I can get it started ok, then it just stops. I want to avoid using a wrench. Could I figure out the size of the thread and run a thread die over it and try and cut/clean new threads??
Any thing else? Thanks, Ian |
Exposed threads on what???? Need a bit more information here.
How to clean up/cut new threads on Filter housing male side
I'm having trouble getting a line to screw in by hand. I don't want to use a wrench if fear of the dreaded cross thread.
Can I cut/clean new threads? Anything else to get this to work? thanks, Ian |
We still don't know what you're trying to clean up, but a die can probably be run over those threads to straighten them.
I'll guess it's about the brake lines
There's a previous message that references the oil tank - maybe it's oil lines or the filter?
I think he's talking about the oil filter neck that threads into the filter itself.
I think the answer is yes - you can simply run a die over the threads to clean them up. I do it all the time.
For really big stuff, they make a tool called a "thread restoring file". Greatest thing in the world for fixing buggered up threads. Mike |
| All times are GMT -8. The time now is 05:15 PM. |
