Freaking out!
I just received a call from my mechanic. I knew he wasn't calling to say the car was ready; he was calling to tell me I'm going to have to spend more money -- I'm already spending at least $800 more than I really can because I can't find an original RSR injector. But I digress.
Basically, one of the RSR injectors is refusing to come out of its hole because someone used Loctite to make sure it would never come out without a fair bit of effort and blasphemy. As it turns out, my mechanic broke the injector trying to unscrew it. And the injector is still in its threaded hole.
My mechanic called to ask me if I could visit his workshop on Friday so he could show me what's involved in getting it out. He thinks heat is going to have to be used, which, I assume, carries some risk with it.
Does anyone think it'll be as involved -- and as risky? -- as it sounds? What could go wrong? What's the worse case scenario here?
Matt Holcomb
1990 Mazda MX-5 (Miata) -- SOLD
1974 911 RS 3.0 replica -- SOLD
1974 911 Carrera 2.7 (MFI) -- SOLD
1976 911 2.7 -- SOLD
Old 04-14-2004, 12:07 AM
Gon fix it with me hammer
svandamme's Avatar
heat is a common practice to try removing stuck bolts
the only thing risky might be an open flame where there normally is fuel involved... so i guess your wrench will have added work removing things that contain fuel , like the fuel lines...
also the shroud probably needs to be removed since it might melt..
so all the intake and injection parts might need to be removed...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-14-2004, 12:32 AM
Buy them, sell them
Adam's Avatar
Is the broken injector being replaced for you, or is it a "hazard of the job"?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 04-14-2004, 01:34 AM
Buy them, sell them
Adam's Avatar
Matt, I talked this over with Joe Cefai over a couple of beers tonight and he was totally shocked that your mechanic forced the injector so hard that it broke off! That's a lot of force!
We kicked the topic around for a while and he's of the opinion that the cylinder head will likely need to be removed (depending on it's location - ie, which cylinder) and the remaining piece of injector tapped out. It's (unfortunately) probably the only way to get it out without putting the car at major fire risk by using heat.
Old 04-14-2004, 05:03 AM
chrisp's Avatar
Lock-tite releases with heat. You may be able to use a heat gun to get the temp up to the critical release temp for the red loctite. There won't be an open flame this way either.
On Loctites website there are specs for red threadlocker and it will outlne the release temp.
'83 SC
Old 04-14-2004, 05:10 AM
Rick Lee's Avatar
What kind of engine is this? I recently had the pleasure of removing the original injectors from a '77 2.7 and it was quite a job. We used a flat tip screwdriver, a BFH and finally a C clamp to press them out. This was with the intake runners off the engine and it was still a b!tch.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-14-2004, 05:40 AM
Adam,
Louis didn't mention anything about having to remove the cylinder head, but that's not to say it's something he won't have to entertain!
Chris,
Thanks for the heads up. If my mechanic isn't already aware of the release temp info, then I shall point him in the right direction.
Richard,
It's a twin plug, MFI 2.9; MFI injectors screw into their holes. Correct me if I'm wrong, but you only have to push in -- or pull out -- CIS injectors.
Matt Holcomb
Old 04-14-2004, 04:42 PM
Bugger!
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 04-14-2004, 06:00 PM
Early_S_Man's Avatar
Porsche Crest
Matt,
Sorry to hear of this big pain ...
I think the best course would be to remove the head ... it may not make the removal easier, but fewer things in the vicinity can get collateral damage!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-14-2004, 06:37 PM
Zeke's Avatar
Different kind of injector. It screws in.
Old 04-14-2004, 06:45 PM
Buy them, sell them
Adam's Avatar
Joe figured it would be best to remove the head anyway, because if you're tapping the injector out, the shavings and debris from inserting the tap would drop down into the combustion chamber.
Old 04-14-2004, 07:04 PM
Buy them, sell them
Adam's Avatar
LOL @ Richard! I just realized what a BFH is.
Old 04-14-2004, 08:26 PM
