-   -   Flunked the emissions test (http://forums.pelicanparts.com/porsche-911-technical-forum/158528-flunked-emissions-test.html)
GSpreeman 04-14-2004 08:49 PM
I flunked the NJ car inspection today due to excessive emissions. I intend to change the plugs, distributor cap, distributor rotor, air filter. What else should I consider to get my car to pass (I don't have the print out in front of me but, it wasn't that bad but, bad enough not to pass).
Lorenfb 04-14-2004 09:08 PM
Things to check:
1. O2 sensor working
2. air flow meter is stock (no adjustments made)
3. fuel pressure is O.K.
4. CAT has not been removed
5. No performance chip
6. temp sensor O.K.
Check out this web site (www.systemsc.com) on the Problems page.
Thack 04-14-2004 09:20 PM
What were the NOx and CO readings? A car 17 years old probably has a used up cat converter.
Joe Bob 04-14-2004 10:30 PM
Do all your adjusting during or followed up with an exhaust gas anlayzer.....if all else fails...accidently pull an injector wire...instant air pump and diluted exhaust gas.....
edit for spelling....:rolleyes:
RickM 04-15-2004 06:29 AM
Greg,
PM me if you flunk again.
Good Luck
