Question electrical moron in need of advice
ok, im not great w electrical. not bad, but not great.
someone please describe how to make the cigarette lighter
hot all the time by modifying the wiring at the fuse box, if thats possible.
ok, whoever can come up w a solution theres a 20 in it for ya.
i swear
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-23-2004, 05:46 PM
Early_S_Man's Avatar
Porsche Crest
Jason,
As I see it, you will need to separate the Black wire to the lighter from the Blue wire from Fuse 13. Then, you can splice the Black wire to a new inline fuse holder run directly to the battery positive terminal.
The diagram below may help ... assuming you haven't already looked at it.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-23-2004, 06:22 PM
thank you. yeah i looked at it. and thats kinda what i thought, but i wanted to ask.
next ques,
whats the best way to access the rear of the cigarette lighter?
Jason
81 SC
97 328is
Old 04-23-2004, 10:36 PM
Send a message via AIM to fintstone
Option 2..disconnect the black wire where it goes into fuse 13. Connect it to an in-line (25a) to the battery or the input side of any unswitched fuse where the input wire is larger than the black one you removed.. Remove the bulb from the fan light. Write down what you did and put it in your owner's manual for the next guy.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-24-2004, 12:16 AM
