rear wheel camber adjust how to ?
My driver side rear wheel is at an angle of perhaps 10 degrees
with the bottm of the tire out and the top in all other wheels seem to be all ok what is the problem and how can I correct it? Thanks Tony
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 |
Is that rear corner sitting lower than the other corner? 10 degrees is a ton, 2-5 might be more like it, 10 would probably be an indication of a pretty serious problem.
My first guess would be that the bushing is really bad, but it could be alignment or bad torsion bar too. You'll have to get in and poke around most likely to find out for sure unless you'd rather take it to a mechanic. If you don't know of a good mechanic in your area if you post where you live possibly another Pelicanite can recommend someone in the area.
