-   -   Large wrench sizes needed (http://forums.pelicanparts.com/porsche-911-technical-forum/158851-large-wrench-sizes-needed.html)
Randy Webb 04-16-2004 10:19 PM
What large size wrenches are needed to work on a 911 -- i.e. larger than 19 mm?
22mm is needed for something or other, right?
there are the nuts on the steering wheel
and on the rear swing plate adjusters - what sizxe there?
what else?
Doug Steinel 04-17-2004 05:39 AM
The steering wheel is held on by a 27mm nut... but you don't /can't use a wrench on it. You need a socket with extension.
RoninLB 04-17-2004 06:23 AM
maybe a full set of Harbor Freight 1/2in rachet, sockets, large wrenches, flex head rachets, etc. is inexpensive enough to get started. Then you'll know what items you'll need to dial in.. like the short Snap-On swivel sockets are a bit unique because they are very short.
avi8torny 04-17-2004 06:34 AM
32 and 36 for the oil lines
ChrisBennet 04-17-2004 06:44 AM
The trailing arm ride height adjustment requires thin 24 and 36mm wrenches. 22mm also fits the O2 sensor on cars with those.
-Chris
Oldporsche 04-17-2004 08:51 AM
I have, when necessary, that the pawn shop sometime has old large wrenches. I take them home to modify with a dremel tool. This gives me the right size at a modest cost.
David Duffield
mm86911 04-17-2004 09:17 AM
22mm for rear lower shock bolts, inner banana arm bolts and front upper strut mounting nuts.
beepbeep 04-17-2004 09:37 AM
32mm 2/3-inch socket for rear hub.
Randy Webb 04-17-2004 03:52 PM
Thanks folks - but let me clarify this. I am not purchasing wrenches. Instead I have a big Snap-On set of closed end wrenches. I notice that over the years I never use the big ones at all. I am thinking of putting the ones I will never need on eBay and clearing some space in my tool box.
So far, the only normal closed end wrench I see that is needed is the 22 mm one. True? It looks like everything else is either a special wrench (oil lines) or a socket. ...
