Question 83SC Clutch pedal on floor
Thought I broke a clutch cable, but no. Tranny repaired last mo. after son's disagreement with 1st gear. OK for 3 wks then grating noise for 1/2 mile while pulling over and pedal goes to floor. Would broken throwout arm behave this way?
Old 04-18-2004, 07:06 PM
yes it does. also check the roll-pin that attaches the clutch pedal to it's shaft. they shear, completely or partially.
206 637 4071
Old 04-18-2004, 07:10 PM
Clutch pedal and cable (new now) seem ok back to tranny. It's as if the helper spring is "past center" or something like that.
Old 04-18-2004, 07:18 PM
if you retighten the cable, whatever is failing usually finishes breaking and gives you a clue.
206 637 4071
Old 04-18-2004, 07:55 PM
I guess it looks as if I'll have to drop the engine again!
Old 04-18-2004, 08:00 PM
