vash's Avatar
argument with a friend, LSD
i am in a discussion with a friend. i search the past LSD post and got confused. with both back wheel in the air, you spin one wheel, the other one DOESNT move at all. that doesnt mean there is a LSD present, right? as i understand, both wheels need to spin in the same direction. correct? we both agree opposite means open diff. what the heck is the other wheel not spinning?
cliff
poof! gone
Old 04-17-2004, 08:58 PM
I am pretty sure with LSD both move the same direction, if only one moves or they move opposite direction then you DON'T have LSD.
I'm sure an expert will tell us for sure here soon.
Old 04-17-2004, 09:05 PM
Eric Coffey's Avatar
What Steve said.
Old 04-17-2004, 09:12 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Unless it's in gear, right?
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 04-17-2004, 09:59 PM
drag racing the short bus
dd74's Avatar
Steve's correct.
The Terror of Tiny Town
Old 04-17-2004, 11:06 PM
Now in 993 land ...
aigel's Avatar
Both wheels turn in the same direction. Out of gear with the brakes off, that is. I think it's $1800 at parts heaven for a used LSD! Yikes!
George
stock LSD
81 SC (sold)
Old 04-17-2004, 11:11 PM
Blockchain Tech Inventor
jrdavid68's Avatar
If you spin one wheel and you see pretty colors, then yes, it was LSD.
A Mean Green Lifted 1972 C10
Long live the king!
Old 04-17-2004, 11:39 PM
If the car is in the air, and in neutral, if you can spin one tire one direction and the other spins the same direction, then it is an LSD (clutch pack style LSD).
Doing this in gear will cause you not to be able to spin the tire if the car is an LSD (clutch pack LSD) (by hand).
But, if the car has a torsen type LSD then it will act exactly like an open diff with respect to the above mentioned test.
TonyG
LSx 951 with 997 Cup Suspension - vision944.tonygarcia.org
3.6L 911SC - www.tonygarcia.org/911SC
Old 04-18-2004, 12:41 AM
Team California
speeder's Avatar
If the car is in gear the wheels will turn in opposite directions w/ factory LSD, (turning one rear wheel by hand, other turns opposite), but in nuetral the other wheel will turn same direction. That is the only true "on the hoist" test, a non-LSD car won't do that trick.
Denis
Old 04-18-2004, 01:26 AM
