In search of set screws to plug air injector holes
I am removing the air injection system and I am looking to plug the hole on the cylinder head. Does anyone know where I can get a 10mm 1.0 pitch hex head set screw? I have tried all of the local hardware stores but have not yet had any luck.
Thanks,
Old 04-26-2004, 01:04 PM
MT912RS's Avatar
Try EBS.
Old 04-26-2004, 01:07 PM
The part you need is sold as a SS plug for 914 rear brake rotors, probably available from our host, I found them at a local Porsche shop that had acquired a ton of them years ago.
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 04-26-2004, 01:08 PM
Mercedes Benz 450 SEL torque convertor drain plug. Can even buy the sealing washer. Did mine recently almost looks as though the factory had pugged the heads. Can get them at the local dealer.
Todd
Old 04-27-2004, 02:08 PM
vash's Avatar
let me give a shout out to jim sims. i posted this same que and he sold me six with the crush washers. i think i bought alot of them. still have yet to use them, waiting for SSI funding.
poof! gone
Old 04-27-2004, 02:11 PM
CHILI's Avatar
Todd
Good call! I heard that they were from MB. Actually Darren @ Pelican told me that. I beilieve the MB plugs are an allen head whereas the 914 part is a philips head. Although, I could be wrong. Mine are allen head. Looks nicer and easier to install. I bought the set from my mechanic who pulled them off of a doner motor. He has said they are getting hard to find. Hope not.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 04-27-2004, 02:14 PM
vash's Avatar
the ones that jim sold me have a regular nut head.
poof! gone
Old 04-27-2004, 03:04 PM
beepbeep's Avatar
Changing 930 dump-gaskets, pictures galore
Thank you for your time,
Old 04-27-2004, 03:07 PM
Somewhere in the Midwest
MotoSook's Avatar
Got the plugs for my engine from NAPA Auto Parts. Standard bolts...the size escapes me, but that has been posted before.
If you can't find the size (you can order hex or allen head from a number places), I have spares that I can measure..
Good luck.
Old 04-27-2004, 03:32 PM
OldTee's Avatar
Buy them from Pelican. They will include the washers. I did.
Old Tee
all 911s sold
Old 04-27-2004, 05:17 PM
justesen's Avatar
Try Maryland Metrics, I bought the perfect plugs when I removed my AI system. The plugs are tapered steel screws with an allen head, DIN 908 10X1. The crush washers are copper DIN 7603 10X13.5X1. I believe six plugs and six washers cost about $5.00. This is a wonderful sight for metric stuff.
Jay
I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant!
Old 04-28-2004, 06:37 AM
The holes are not tapered; one needs straight M10 x 1 threads on the plugs to properly fit the air injector holes in the heads. These plugs are available from a variety of sources including apparently Pelican although I couln't find the plugs in their on-line catalog. Jim
Old 04-28-2004, 07:38 AM
CHILI's Avatar
You're totally right. I wrote philips head, but I meant a normal bolt/nut head. I prefer the Allen heads, though.
Anyway, yes Pelican carries the 914 brake plug and washer set that works. Call Darren, he knows what they are...
(888) 280-7799 X 223
Chad aka "Chili"
Old 04-28-2004, 08:48 AM
justesen's Avatar
No, the holes are not tapered but the nozzle that screws into the head has a slight taper between the base of the nozzle and the start of the threads to allow for the centering of the gasket as it is tightened. The plugs I mentioned from Maryland Metrics have this slight taper.
Jay
77 911S
36,000 ORIGINAL miles
Old 04-28-2004, 09:09 AM
