Paul Valcourt's Avatar
Detailing in trunk pics
I figured it was about time to clean up some of the mess left by the PO. It took me two weekends but was worth it.
75 targa 2.7
Lean and green
Old 01-16-2004, 10:52 AM
Certified Pre-Owned
BGCarrera32's Avatar
Nice job! Here's what I did last year...
Before:
After:
'84 Carrera Coupe
Old 01-16-2004, 10:59 AM
BGCarrera32, nice job on yours. I found most of the time was spend sanding and masking. What my before picture didn't show was the hinges, they were red also. It didn't look very good when I opened the trunk with all that red on a green car.
75 targa 2.7
Lean and green
Old 01-16-2004, 11:09 AM
Certified Pre-Owned
I thought removing the cosmoline/wax garbage all over the seams of the sheet metal was the worst part...I also removed all the HVAC stuff and cleaned it out piece by piece...I must be nuts.
'84 Carrera Coupe
Old 01-16-2004, 11:55 AM
curlesw's Avatar
Both look great!
v/r
Wayne C.
83 SC
Old 01-16-2004, 11:59 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
Ok - so what's the best way to clean up the trunk?? - I have to do that now that summer is approaching - well at least in Southern California it is.
Old 01-16-2004, 12:05 PM
Certified Pre-Owned
After I stripped my tank, I used this stuff (see my comments in the link)
Where the H--- to get Wurth SKS Stone Guard????? Help
'84 Carrera Coupe
Old 01-16-2004, 12:42 PM
sithot's Avatar
http://www.colorplus.com/
These folks supply the original Gas Tank Grey paint/stain that is used by John Paterak and some of your better know show quality restoration shops.
It can be brushed or sprayed although you cannot tell the difference so I usually brush it on. Makes your old gas tank look like new. I guarantee it because I've used it many many times in the past.
They also make very good leather dye formulas.
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 01-16-2004, 12:59 PM
Gon fix it with me hammer
svandamme's Avatar
all i've got to show for right now is a before pic...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-16-2004, 01:53 PM
Pete000's Avatar
Nice Trunks!
Work to Live, don't live to work...
Old 01-16-2004, 01:56 PM
Oh yes, I can remember being there. Made in aluminum:
drilled smuggler's box lid
fuse box
brake fluid bottle bracket
fuel sender connection protector
ventilation protection plate
undertray for the steering rack
And to follow shortly, an aluminum hood.
Old 01-16-2004, 01:58 PM
svandamme's Avatar
what is that ? a 100 Liter tank? or did you modify it?
i have one with room for an inflatable tire but that's useless
i'm thinking about flattening my trunk with a board with the carpet tight on the boar, no carpet on the side
then make a thing to fix my full size spare tire in the back/center of the trunk
then make a board for the blowers and stuff, but completely covering
Stijn Vandamme
Old 01-16-2004, 02:09 PM
That is a 106 liter tank (cut and weld). I got it cheap from a guy, cleaned it and repainted it. I am working on another of the same kind but with center fill "à la JPNovak"
Old 01-16-2004, 02:17 PM
tobluforu's Avatar
All that aluminum and you still have the spare and the smugglers lid. You don't need not stink'n spare! Or a lid for that matter.
Now an aluminum hood-that's sweet!
Nice trunks!
Old 01-16-2004, 02:28 PM
svandamme's Avatar
Nice trunks!
you don't need it till you're in the middle of nowhere with a flat, and don't talk fix-a-flat , cause you can bet on it that when you are in the middle of nowhere, it's not going to be a small puncture and you will be stuck.
Stijn Vandamme
Old 01-16-2004, 02:46 PM
tobluforu's Avatar
I'll probably get hit with karma the next time I take toblu out because of my comment.
Old 01-16-2004, 03:56 PM
svandamme's Avatar
i think it actually looks nice to have a full size tire when you pop the hood of a 911
if it's not a track car with weight reductions all round, and you are using it as a fun car for touring, then the extra weight up front makes the car more enjoyable when it comes to handling. i actually drove with a sand bag in the front just for this reason, it's a cheap insurance for the old back of the car coming out of the corner before the front of the car thing.
and superior driving skills will not save you if you happen to come across a bad piece of asfalt with either oil or another thing that makes your car loose grip where you don't expect it, once it breaks out a 911 doesn't recover well. 50 kilo in the trunk can make a the difference in these sort of situations.
i travel light so i don't need a trunk that will store 5 samsonite cases, i can do 1.7 weeks on the trolleybag thing that fit's in overhead compartments of airplanes , and it still fits in the trunk next to the full size spare...
Stijn Vandamme
Old 01-16-2004, 04:14 PM
Raynald's Avatar
trunk
Hello
this is my work... and we never finish to work on it !!!
Ray
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 01-16-2004, 04:39 PM
svandamme's Avatar
looks sweeeeeeeet
Stijn Vandamme
Old 01-16-2004, 04:58 PM
Randy Webb's Avatar
Raynald - is that an aluminum plate across the front where the wiper mecahnism, etc. is? If not, what is it? Thx.
Old 01-16-2004, 06:19 PM
