Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
brake bleed nightmare
Hey Guys,
I've been trying to get my brakes bled on the 912-6 with low sucsess. I followed the recent thread of pulling the pads to move the pistons, and using my home made pressure cap to pressure bleed the lines, plus I tapped all over the system to dislodge any air bubbles. With the pressure system pumped up, the pedal is hard, no pressure, pedal is on the floor. With the regular cap on, I can pump the pedal short a few times and the pedal gets hard, press again and its on the floor.
When I check the rotors with the pedal on the floor, the rears are stopped, the fronts have medium drag, but I can rotate them.
Sooooo, have I still got air in the system, or is the MC bad. I don't see any leaks on the floor board, and no big puddles on the floor.
Or can I find a pressure bleeder at pep boys or somewhere this weekend?
Help help help help help!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 04-16-2004, 06:03 PM
72 four door's Avatar
John i just did mine and had a sorta the same problem I cracked the lines on the master and let it gravity bleed then i did the same on my fittings pedals nice now. Although primitive it worked well.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 04-16-2004, 07:19 PM
Stahlwerks.com
jhelgesen's Avatar
Okay, I'll give it a try, thanks!
John Helgesen
Old 04-16-2004, 07:45 PM
one of gods prototypes
bell's Avatar
if you had the calipers off make sure the bleed nipples are at the TOP of the caliper carrera calipers can be mixed up, not sure if yours can be.....don't ask how i know
Brought to you by Carl's Jr.
Old 04-16-2004, 08:08 PM
Ya know he right this just happened to me last week on my sons jeep check that out
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 04-16-2004, 08:12 PM
Zeke's Avatar
The M/C is suspect to me. I've read here that many times the M/C goes away when you bleed the brakes because you push it in further than it's been for a long time, run into rough and rusty territory with the cup seal, and blam, it's toast. I don't know for sure because the first thing I do with a car that needs any brake work is buy a new M/C.
Old 04-16-2004, 09:36 PM
Early_S_Man's Avatar
Porsche Crest
How loose are the pads in the caliper? Lots of clearance = lots of pedal travel required , and there is a point at which the master cylinder doesn't have enough volume in one piston stroke to push out all four 48 mm pistons enough to apply much force on the rotor!!!
If the front pads have enough clearance that they come out easily, or if you can wiggle them ... then you need to remove them one at a time and bump the brake pedal to take up the slack ... you should have to hammer the pads back in with a plastic mallet, or you might have to pry the piston back in slightl;y ... if you pushed one out too far. The clearance should be zero putting pads back in!!!
Read this thread for a thorough discussion of the matter and the solution:
Brakes
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-16-2004, 10:12 PM
Had this problem long ago. My Pads were too thin, Problem solved with new pads ! Doh
Old 04-17-2004, 02:53 AM
sundaypunch's Avatar
Are you sure your homemade pressure cap is working? Sometimes homemade isn't a good solution. I would invest the $41 or so in the Motive bleeder. I would also echo Zeke's comments about the M/C if the pressure bleeder doesn't solve it.
Old 04-17-2004, 06:47 AM
Warren's info is necessary to prevent chasing your tail.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-17-2004, 06:59 AM
Stahlwerks.com
jhelgesen's Avatar
Okay, just got home late and ran out to the shop. Bled the mc with my helper, then went back through the calipers again. Kept hearing a gurgling sound in the right front. Pulled the line from the caliper and gravity bled it a while, then reinstalled and bled the caliper again. Pedal feels better, but I would say its at 40% where it should be. I'm headed to the hardware store early tomorrow morning to make a propper bleader system and try one more time.
John at PP said my new MC should be here tuesday if this doesn't work.
I'm getting closer and closer to taking a rental car to drivers ed.
John Helgesen
Old 04-17-2004, 07:56 PM
Could be that the part of the Master cylinder that runs the front circuit needs to be bled.
Old 04-17-2004, 09:57 PM
Do you 'bleed' the MC by just loosening each line & letting it drain, or pumping the pedal (making sure the reservoir doesn't run dry)?
Old 04-17-2004, 10:48 PM
Stahlwerks.com
jhelgesen's Avatar
Signs are pointing more and more to the MC. Pressure bled the MC f&r, then the whole system this afternoon with no improvement. We'll see what happens this week when the new MC arrives.
John Helgesen
Old 04-18-2004, 07:22 PM
vash's Avatar
start getting yourself mentally prepared to handle those damn grommets on the top. are you going to bench bleed this time?
poof! gone
Old 04-18-2004, 07:40 PM
