Tire pressures for a DE event at Streets of Willow
Tomorrow there's a PCA event at Streets of Willow. I'm taking my stock 86 Carrera coupe up there and would like to know what tire pressures to run. When I autocrossed it there were so many opinions that I ended up trying several set ups.
Not sure if there was a difference!
On the Willow course I just want to make sure that I'm running safe pressures that will be good for the day. I don't plan on pushing the car but then again I never do at autocrosses and then... you get the picture.
Pete
86 Carrera
1986 Carrera Coupe Iris Blue
1990 Mercedes 190E 2.6 Smoke Silver
1986 Cadillac Fleetwood Brougham Chamois
Old 04-18-2004, 03:28 PM
ttweed's Avatar
What region is putting on a PCA event on Mon. the 19th of May at SOW? I don't see it on the calendar at the Zone 8 website.
There are many variables to your question, including what tires you are using and what the ambient temp is at the track. With most street tires, I would start at 32F & 34R cold pressures and then check them when you come off the track. Don't go much over 40 psi hot- if they gain more than 6-8 psi in a session, bleed them down to 40 hot.
These settings may be on the high side, but you said safe, not fast.
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-18-2004, 06:06 PM
cvfncrew's Avatar
Hey Pete-
I will help you tomorrow with tire info.
The 914/6 would be alot of fun at SOW. Are you sure you don't want to bring that?
Christian #85
"YELLORS" 1972 911T with a 3.4l, PMO 46's
Vierte Tür Klub Member.
PCA National DE Instructor
Old 04-18-2004, 06:07 PM
