Rodney Nelson's Avatar
where is the fuel pump check valve?
I am having problems with warm starts on my 82 SC. I did a lot of searching and found out that I should replace the fuel pump check valve first.
So I bought it asap from pelican, but I can't seem to find any pictures or description of exactly where it is and how to remove it.
Is it just located on the fuel pump or what?
If anyone has a diagram or pictures that would be awsome.
Thanks,
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 04-20-2004, 09:08 AM
never ending projects
niner11's Avatar
If you remove the fuel pump it should be pretty easy to see where your new check valve goes. Sorry I don't have pics for you. Your local fire department will thank you if you disconnect the battery first. Good luck
Old 04-20-2004, 10:01 AM
Cool, thanks.
I just wanted to make sure that it was necessary to remove the fuel pump, since I could not find any documentation on the procedure.
Old 04-20-2004, 10:25 AM
