-   -   Dyno Day question (http://forums.pelicanparts.com/porsche-911-technical-forum/159158-dyno-day-question.html)
Wil Ferch 04-19-2004 09:08 AM
Dyno Day question
Folks:
I'm facilitating our local club's Dyno day at a local shop. I was hoping that the shop would be in a position to measure air-fuel ratio as we do the various runs. It looks like they are not equipped to do this. Nor can they do CO readings ( which can be crudely compared to A/F via a generic table).
Any hints of what we can yet do to make this more meaningful ?
---Wil Ferch
ttweed 04-19-2004 10:53 AM
Ummm, find another dyno shop? I wouldn't pay to put my car on a dyno that couldn't give me A/F readouts for the whole run, myself.
YMMV,
TT
tobluforu 04-19-2004 10:58 AM
If any of the cars are turbo's, you will want a\f to be measured for sure.
My car is not a turbo, but I would still want to know. Find another shop.
Bill Verburg 04-19-2004 06:03 PM
Doesn't Joel Reiser live out your way? You might try contacting him for some direction
ValveFloat 04-20-2004 12:23 PM
This might help
http://www.dynojet.com/maps/autodynos/ny.htm
kstylianos 04-20-2004 12:58 PM
How about an LM-1 with an RPM pickup. Maybe someone locally has one.
If you ask the dyno shop, they'll usually provide you a floppy with the necessary data that you can import into Excel. Do the same with the LM-1 and you'll have your hP, torque, rpm and AFR.
Wil Ferch 04-22-2004 09:45 AM
Thanks for all the suggestions.....
---Wil
tsuter 04-22-2004 09:47 AM
Yikes is right!! Find another shop!
Wil Ferch 04-29-2004 09:04 AM
Well...did some searching and found a shop that met the criteria of being relatively close, can do A/F monitoring, and will give a flat unit price "per car" regardless of number of cars that attend ( helps guys like me who organize this sort of thing).
Still a problem...although rather minor, perhaps. The new shop uses a "Land & Sea " dyno , set up as an inertial unit ( like DynoJet248C)..but I have no reference as to what kind of numbers this unit spits out..and how comparable to 248C base-runs this might be.
So... anyone ( here?) ever run on both of these types of dynos with no changes done to the car in the interim ??
---Wil
