Quick question on updates to drivetrain
Soon I'll be replacing my clutch. This is good and bad...good because my ring-gear and maybe starter gears are grinding frequently, bad cause of the costs...
My question...when the motor is out and we're doing clutch work...I'd like to hit all TSB updates and things at the same time...thus, can someone post all the things I should consider when I'm in...?? Thanks...Phattey... |
Get the clutch fork shaft update that utilizes bushings instead of needle bearings or drilling the case, get the new clutch fork.
that's it. |
| All times are GMT -8. The time now is 05:31 PM. |
