-   -   Re installing brake pads (http://forums.pelicanparts.com/porsche-911-technical-forum/159618-re-installing-brake-pads.html)
Brent 930 04-22-2004 08:32 AM
I went back to install the stock brake pads which are thicker and those pistons are not budging. I don't have that special tool I see in my book to spread them apart so what are my options?
Hugh R 04-22-2004 09:43 AM
Pull the caliper off and use a large wood clamp.
juanbenae 04-22-2004 10:01 AM
have you removed the cap on the master cylinder? watch for over flow of the MC when you push them back in.
Brent 930 04-22-2004 10:12 AM
There must be a better way then to pull the calipers off everytime you want to change the pads. I guess if I got that tool I saw in my book it would work for me.
Brent 930 04-22-2004 10:20 AM
I have an idea
Rot 911 04-22-2004 10:22 AM
Hell I just take a BF screwdriver and wedge it between the piston and the rotor and just give it a twist. Never had any problems doing it that way.
OZCarrera3 04-22-2004 10:25 AM
Ok, one of you guy's had to put me away! I wan't a pair of 8 or 9 inch wheels! Can sonwobwe accomodate me ?
pwd72s 04-22-2004 10:54 AM
Don't use the screwdriver trick! You don't want to scratch the finish on your pistons or damage a seal. Do you still have your old brake pads? If so, put them back in, then use your screwdriver between their compound and the rotor. The plate of the old pads will protect your pistons & seals, and since they are to be replaced, marking up their compound won't matter...
CHILI 04-22-2004 10:57 AM
And with any brake job (not just P-cars) don't push too quickly. That's when you can create problems such as MC overflow and broken seals. Just let the C-clamp or specail tool/BF screwdriver do the work. I.e. don't force it. ;)
mike f 04-22-2004 12:45 PM
You can also use a really large pair of channel lock pliers between the old pads and the calipers. Just protect the caliper side with a rag or a piece of rubber.
Emission 04-22-2004 12:47 PM
I use the brake tool, or a C-clamp - slowly.
Brent 930 04-22-2004 01:18 PM
Thanks, what is the brake tool?
jbripps 04-22-2004 01:36 PM
The tool is actually called a brake pad spreader...it is sold by our host.......looks like an "X" with a twist fly bolt that slowly spreads the ends. Like like a surgical tool.
The C-clamp should work well also.....that's what I use on the other cars.
Brent 930 04-22-2004 02:36 PM
Thanks guys, that is the info I needed. Nothing like experience,
Brent
