-   -   Stipping ...... Fuchs (http://forums.pelicanparts.com/porsche-911-technical-forum/159778-stipping-fuchs.html)
Pettybird 04-25-2004 02:27 PM
looks fantastic...
did you take the tires off? (did i miss the answer to that question?)
what does that stuff do if you get it on rubber?
what did it do to the paint on the centers?
thanks
doug
Jeff Alton 04-25-2004 04:33 PM
Doug, two wheels had tires and two did not. It had no effect on the factory paint, but I am not sure what it would do to paint that someone else had applied. The cleaner did absolutley nothing to the rubber- tires or my gloves. Skin, now that is a different matter all together!
Jeff
ASD 05-11-2004 10:36 AM
you might consider using Liquid Glass sealant to seal that shine in, I did that to my Airstream and it sealed the aluminum skin very well. It has lasted for 6-7 months thru winter weather also. 17 bucks a bottle at Pep Boys and other places, but a little goes a long way. One can did my 28' rig twice with a little left over.
Jeff Alton 05-11-2004 12:35 PM
ASD, thanks, i will try that.
Jeff
89911 05-11-2004 01:49 PM
Having done this a few times, I would say stripping the anodization off is about 25% of the work involved getting them to a fully polished look. Just doing the rims saves a lot of extra work. It also helps to have the valve stem off them if possible. Nice work, and see, you didn't need to send them out!
