-   -   Geeeeez, another PPI ? (http://forums.pelicanparts.com/porsche-911-technical-forum/159838-geeeeez-another-ppi.html)
Westy 04-23-2004 06:46 PM
My PPi just indicated 150 in all cylinders. Now I'm hearing you guys talking about 170 and 175. 20-25 diff? Whasup with that????:confused:
vash 04-23-2004 06:47 PM
from what i learned it isnt the numbers, but the consistency.
Westy 04-23-2004 06:49 PM
Yah, but I'm not constipated! Oh,,,um,,, never mind
nostatic 04-23-2004 06:54 PM
also depends on the year and engine model. And how well the test was done.
Westy 04-23-2004 06:56 PM
81 SC. Should be the same as 80 thru 83,,,right???
yelcab1 04-23-2004 09:58 PM
I would be happy with 150 all across.
aigel 04-23-2004 10:20 PM
Absolute numbers are practically meaningless. Here is only a few factors that can change the absolute number tremendously:
air pressure
temperatures (outside and engine)
battery power
starter
what's with the other spark plugs?
throttle open or closed during test?
the compression tester used (none of them are absolutely calibrated).
So, you see, any of the above factors can get you lower or higher than numbers you read on the board.
To clarify: It is important that your numbers are within 10% of each other. Take your highest number and subtract 10%. If all other numbers are within that range, you are okay.
George
