Gon fix it with me hammer
fuel lines & CIS
calling out to y'all CIS guru's
have a question about the fuel lines i know with MFI the length of the lines has to be identical for proper operation, but i haven't been able to find any information about the lines when using CIS do they have to be identical? or are they supposed to be a certain length something to match the output on the fuel distributor for each cylinder? none of the CIS/K Jetronic websites out there mentions anything about the fuel lines it's actually for my 923, got fuel problems and a busted line replaced by another doesn't seem to do what i hoped it would but i guess i'll find more CIS folks here than anywhere else
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
19 years and 17k posts...
Stijn,
I don't believe the length of the fuel lines matter in CIS because the fuel system pressures are built up and maintained by the system and remain relatively constant. I could be wrong, but I've replaced almost all of my fuel lines and I've adjusted the length to make them easier to route/manage...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Recreational Mechanic
My CIS lines are all different lengths. I have the hard steel ones. I know some earlier models used flexible plastic lines.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
hmm, the green bugger started running like a 3 legged horse shortly after i replaced the rear fuel pump, i pulled the plug wires one by one and pulling the plug on cyllinder 1 didn't make any worse running engine
so me figured that must be the one not running checked timing , spark , valves , compression must be something in the fuel delivery then i loosened the fuel lines one by one at the distributor and again , the one for Cyl 1 was the only one that didn't make the engine run worse... pulled injector, wasn't spraying... replaced line and injector... verified it... it sprayed.. but still no joy... that's when the owner of the garage said the lines should be the right size... but i doubted it...
Did you check the spark via the plug wire for cyl #1? Maybe the wire is bad? You can measure resistance end to end on all the wires and compare.
did check it , and replaced the wire ...
i'll give it some more attention in an hour , f1 on tv and although it's pretty boring... i'll watch...
stijn. i use a water spray bottle to spray the heat exchangers when i first start the car. the hot cylinders will steam up fast proving that it is firing. a dead cylinder will not. do it fast because the heat will creep.
poof! gone |
not so easy , this is the 4 banger acting up...
i'm pretty sure it's # 1... but have been lazy all afternoon and should be looking at it instead of looking at my tv and computer...
