Targa Window Frames - Bits n Pieces
Hi All,
I need to order some new parts for the door window frames on my Targa. See this picture below: http://forums.pelicanparts.com/uploa...1083155087.jpg The main part I need to replace is (I beleive) number 12, is this the part that the window should come to a stop in (and also joins the frame together)? I also need the screws, number 14. But what about the rivets, number 13, can't see where these go in my car? Please can someone verify what parts I need to swap out number 12. Cheers, Tim. |
#12 is riveted to the frame, so to do it right you need the brass rivets. I gave up on using these though and ended up using one pop rivet to hold it in place. Not a perfect fit but good enough for me.
| All times are GMT -8. The time now is 08:34 PM. |
