electrical part of ignition switch
I am trying to replace the electrical portion of my ignition switch to hopefully cure my starting problem. How do I unplug the wires from the electrical switch under the dash? Does it just pull off, or are there tabs I need to release. Can I stick a screw driver inbetween and pry it apart? Any advice would help!
It is a tight fit but it is a friction fit. Try to wiggle it back and forth, but it will not twist. After you get that off, the electrical switch is held to the ignition housing by 2 small screws. Good luck
Be careful if you decide to get the screwdriver in there, you don't wanna short anything out! (disconnect battery first maybe)
As safecracker says above it's a friction fit, but it's really tight up there! Good luck! Tim. |
I will try again tonight. Thanks.
| All times are GMT -8. The time now is 10:18 AM. |
