nigel911's Avatar
Fan pulley wrench?
Anyone have a sensible alternative to the PP fan pulley wrench? Fan belt is bust, need to replace asap - I'm on the other coast in FL so trying to avoid the delay shipping will incur.
Old 04-27-2004, 05:57 PM
stormcrow's Avatar
I think you might be able to use a 2" spanner wrench that the fire department uses on their hoses. You might stop by one and talk to them about it. They may be able to have a source for you.
"A Porsche does more then just go fast in a straight line"
SteveKJR
Proud Owner of a 78 911 SC Targa
Old 04-27-2004, 06:42 PM
pwd72s's Avatar
I'll probably get a nasty email from Wayne for this. But frankly, the early 911 fan pully wrench he sells is a P.O.C. Buy the replica sold by Stoddards, and it won't bend...Wayne? Before you get too pissed? Think about offering a wrench that really works?
Old 04-27-2004, 07:01 PM
nigel911's Avatar
Made a tool which did the job nicely. Bought a length of flat, one a half inch wide hardened steel, a couple of hardened bolts and nuts. Drilled 2 holes in the flat steel at the correct offset for the holes in the pulley, fitted the bolts one side and the nuts the other, then cut out a rough semi circle to allow a socket access to the fan nut (thanks again Mr Dremel). Less than $10.
Voila, job done.
Old 04-28-2004, 05:57 PM
vash's Avatar
i'd second this with both hands up. i tried to get one from stoddard, but their customer relations are not up to pelican stuff. no version of darren over there! i never heard back from them. anybody (pwd72!) have the exact part number from stoddard? that is where i left it. i thought of making my own version. i was going to copy those old school sprinkler head wrenches, where the prongs are at the end of a U shape wrench, versus the original C shaped version from pelican. BUT I GOT sidetraked into trying to fit a newer type pulley onto my car. thanks for reminding me that this is on my todo list. the spanner wrench makes more sense.
cliff
poof! gone
Old 04-28-2004, 06:29 PM
chuckw951's Avatar
A while back there was a thread about cheap parts that substitute for Porsche...
And I remember reading about a tool available from a bike store that worked as a fan pulley wrench. Perhaps a search can identify it. I need one too for an SC, but $40 is too much for me for a new one.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 04-28-2004, 06:36 PM
vash's Avatar
chuck, you are looking for a bottom bracket spanner wrench. check with park tools. by memory it would seem too small.
poof! gone
Old 04-28-2004, 06:59 PM
Zeke's Avatar
cliff
I don't know, Stoddard treated me 100% when I bought S caliper pistons (Wayne doesn't have these, so I can talk about it)(or didn't have them).
The wrench I have lasted about a minute. Who makes this junk?
Old 04-28-2004, 07:23 PM
stormcrow's Avatar
I was just checking McMaster Carr and they have them for about $6.49 for the 1" all the way up to 6" for about $23.26.
SteveKJR
Old 04-28-2004, 07:28 PM
pwd72s's Avatar
We may be talking two different fan pully wrenches here guys...the one I'm thinking of has the two pins that stick through the pully holes...used on early 911 models, and I'm not sure when the design was changed. Anyway, the Stoddard part number was T52.003.003. I ordered this for Evren back in July of '03 after the one he bought here bent. The Stoddard version is a slightly beefier design than original. The '03 Stoddard Catalog price was $22.90, but if I remember correctly, the ding for shipping was hefty. Stoddard's toll free number is 1-800-342-1414 My overall impression is that the prices are high, and customer service is not up to Pelican standards. But quite often they have items that nobody else seems to carry. And, yes, the early 911 fan pully wrench they sell is MUCH stronger than the one you can buy here.
Old 04-28-2004, 09:58 PM
Kantry Member
oldE's Avatar
Used an aluminum pedal arm from my son's bike that had the big end stripped out. drilled & tapped for a couple of pins (small bolts with the heads removed) and band-sawed part of the remainder of the big end to form the appropriate crescent shape. Its ugly, but it works.
Les
Best
Les
Old 04-29-2004, 04:50 AM
IROC's Avatar
I bought the McMaster Carr version years ago for dirt cheap. I had to file down the diameter of the engagement pin slightly, but it works like a charm. I think it was something like $10.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-29-2004, 05:06 AM
Send a message via AIM to fintstone
Wilding Engineering...(The guy that makes/sells the fancy porsche engine/floor jack adapters) makes a pretty darn hefty looking version of the 65-74 wrench for a competitive price...perhaps Eugene could look into carrying those.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-29-2004, 06:04 AM
na2ub's Avatar
In a pinch, I used an oil filter wrench (one for smaller filters). It kinda bent up because only half the wrench band went around the pully, but it worked. If it makes anyone feel any better about the Pelican wrench, when I first got my car, I bought the Wrong one from Pelican. So, not only did I spend the $$, but I now have a useless early 911 wrench in the garage. I suppose its time I put it in the classifieds. Oh well.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 04-29-2004, 07:54 AM
HarryD's Avatar
I have one of these. They seem ok. Looks like this:
Here is one of Paul's Auctions for reference: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2475014804&category=43998
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-29-2004, 12:07 PM
Rick Lee's Avatar
Maybe it wasn't on tight enough, but I held the fan blades with my bare hands while a friend loosened up the pulley nut.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-29-2004, 01:29 PM
Early_S_Man's Avatar
Porsche Crest
This is one of those cases where improvisation can get it done quickly ... try an impact wrench while an assistant holds a new fan belt wrapped around the pulley ... gripped tight with Channel-Locs ...
Save s a lot of time waiting on the UPS or FedEx truck ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-29-2004, 02:10 PM
