TerryBPP's Avatar
Stock exhaust mounting mods..
I am installing a stock 2 in 1 out on a 2.7 and I do not have the straps or the metal piece that bolts onto the block. I hear the straps are a pain in the arse to hook up anyway. So is it possible to weld a bracket to the muffler then bolt in to the block? Is it possible that the direct connection will crack the heads due to the stiffness?
Old 04-30-2004, 07:19 AM
Original Owner
tsuter's Avatar
I made a metal support bracket w arm to bolt in the stock location (two bolts) and used two muffler straps. If you locate the strap fasteners pointing down on the backside they are easy to get to.
The straps pass thru slots in the bracket arm.
I would not weld the muffler to the support bracket.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 04-30-2004, 07:30 AM
Early_S_Man's Avatar
Porsche Crest
Terry,
Why don't you just order #19 in the diagram below, for a 1974 model ... 901.111.151.04 ???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-30-2004, 08:12 AM
TerryBPP's Avatar
That would be to easy Thats probably what I'll do.
Old 04-30-2004, 08:33 AM
