Ditching exchangers for headers, now what?
After I remove the heat exchangers, what is the next step as far as the tubes that run up to the engine bay? I ask as I am not sure of what the purpose of those are? Do they pull heat from the engine or supply fresh air? TIA for suggestions/advice. -John
Well, you block the flow of air coming from the fan, remove any of the heater tubes and block the inlets to the passenger compartment.
Those tubes send air from the engine fan down throught the HE where it is heated and then sent on into the cockpit when you pull up your heat levers behind the shifter.
I was planning on blocking the tubes running to the interior. But, if I block off or remove the tubes from the fan, will that cause an increase in engine compartment heat? Would I be better off leaving the upper tubes in place so that the fan can exhaust engine heat out?
Part of my problem is I dont fully understand the importance of the upper tubes. -John |
I would remove all the hoses & heater motor as well. It will save you some weight. I also chose to remove all my heater controls in my dash as well as my fresh air blower & control boxes.
Is there a different cover plate available for those not running exchangers? I'm referring to the small triangular shaped covers on either side of the engine fan. If so, what is the proper name for them or better yet, part number? (makes it easier to search for them.) -John |
They sell block off plates for cars running headers. About $75 for that left side one.
Here is a cheaper way to block off the air: Rattlecan caps with hose clamps
http://forums.pelicanparts.com/uploa...1083510273.jpg The engine fan sucks in air and pushes it downwards over the cylinders and heads to provide cooling. Some of that air is used to go to the heat exchangers and from their to the cabin. Once you block of the ducts you'll increase the airflow and hence the cooling of the engine You sure want to leave the engine fan in place. Without it there won't be cooling and no alternator..... Cheers, Ingo |
| All times are GMT -8. The time now is 05:56 AM. |
