on-ramp's Avatar
Stereo install - Should I be worried?
Pulled out old radio with hopes of installing a new CD player.
the plug in the photo (that plugs into the rear) used to be part of a thick black cable. Should I be worried? gut instinct tells me i have a lot more work ahead of me.....
Old 05-02-2004, 08:08 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
That is for your antenna signal - you made need to purchase an adapter and rewire this piece back on as you will need it on your new deck.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 05-02-2004, 08:18 AM
on-ramp's Avatar
another pic.
84porsche's Avatar
I don't know if you can see it clearly but this is what my cables looked like after I pulled the old stereo out -
2003 VW Jetta GLI
Old 05-02-2004, 08:20 AM
on-ramp's Avatar
84 porsche, how did you remove the stereo without that metal rectangular frame in the dashboard?
Mine came all out. (see pic below)
Old 05-02-2004, 08:23 AM
on-ramp's Avatar
More demolition pics.
(what's that grey box? part of radio system or should i just leave it alone?)
Old 05-02-2004, 08:29 AM
That Gray Box looks like an alarm brain to me. Not for sure though what is the Brand name on it?
Old 05-02-2004, 08:43 AM
on-ramp's Avatar
Info on grey box:
UNCO
Model 5100
SR#0036516
i dont believe my car has an alarm
Old 05-02-2004, 08:52 AM
Is that UNGO maybe or UNCO for sure? UNGO is a brand of alarms.
Old 05-02-2004, 09:24 AM
on-ramp's Avatar
ok, it's UNGO then.
now it makes sense....this was on my keychain (from previous owner) so i threw it away because alarm never worked.
i'll just leave it alone then, and just replace all the wiring associated with stereo.
btw, anyone know a good source to buy a now obsolete Nakamichi stereo? (model CD 45z). i prefer the looks/price of this model over the new model CD400...
I looked on Ebay and a few other sources, no luck.
Old 05-02-2004, 09:37 AM
TurboRuf's Avatar
I see the CD 45z on ebay all the time.
Old 05-02-2004, 09:42 AM
Registered abUser
TerryH's Avatar
Re: Stereo install - Should I be worried?
[QUOTE]Originally posted by on-ramp
[B]Pulled out old radio with hopes of installing a new CD player.
the plug in the photo (that plugs into the rear) used to be part of a thick black cable. Should I be worried? gut instinct tells me i have a lot more work ahead of me.....[B]
If you didn't know that was the antenna lead....
and you were working on my radio, I'd be plenty worried!
'81 911SC Coupe SOLD
Old 05-02-2004, 10:19 AM
on-ramp's Avatar
Re: Re: Stereo install - Should I be worried?
[QUOTE]Originally posted by TerryH
[B]
that particular connection was on the verge of disintegration anyway so i couldn't really save it.
besides, i'd rather tackle this project, or any other project for that matter, than to put my faith in some teenage kid down at the Tweeter/Bestbuy center.
Old 05-02-2004, 10:39 AM
19 years and 17k posts...
azasadny's Avatar
I'd recommend that you remove (or have a good shop do it) all of the wiring mess that came with the alarm system. You'll have a much cleaner under-dash appearance and it will make it easier to locate wires, fuses, etc... if you get rid of unnecessary wires. A local stereo/alarm shop removed all of my alarm wires for $35.00 and it made for a much cleaner under-dash.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-02-2004, 11:06 AM
on-ramp's Avatar
my thoughts exactly. it is a wiring mess right now...they need to go and that's what i intend to do.
boy, this stereo install has turned into an alarm dis-install....
btw, how much weight savings will i see/any performance gain?
will post more pics along the way
Old 05-02-2004, 11:23 AM
on-ramp's Avatar
ok, i removed all the connectors from the alarm "brain" (grey box, not shown in pics, currently in the garbage can).
I also cut the grey wire going into the box (wire on the right in the pic) and miraculously, the car still starts.
I must be blessed today.
now where do these thousands of wires go?
Old 05-02-2004, 11:50 AM
on-ramp's Avatar
advice needed.....all these wires are bundled into 1 black harness that snakes over to underneith the drivers side. Can i just cut it and be done with it? (I hate alarms)
Old 05-02-2004, 01:38 PM
one of gods prototypes
bell's Avatar
looking at the relay attatched to that harness it looks to be a starter kill.......if you cut it the car will not start....it'll need to be reconnected (the stock wiring, this is a "loop").......best to trace each wire and disconnect individually so to be sure the stock wiring is intact where the connections were made.
Brought to you by Carl's Jr.
Old 05-02-2004, 01:41 PM
azasadny's Avatar
That's why I had the alarm/stereo shop do the "surgery", I was afraid the car wouldn't start again. There must have been 4lbs of wires, relays and "black boxes" for that old alarm. I'm glad it's gone!
Art Zasadny
www.ford.com
Old 05-02-2004, 01:44 PM
on-ramp's Avatar
so far the car still starts and i cut quite a few wires , maybe 5.....2 went into a button, one into a switch, and 2 went behind the front somewhere.
Old 05-02-2004, 01:51 PM
