Fuchs 16x9 Wheels
Does anyone know where I can get a used set of factory Fuchs 16x9 black center, 15 mm offset, 911 362 119 00, wheels in good condition from? Will accept with tires also.
Thanks, Miles
Miles '80 911sc Coupe Oahu, Hawaii USA |
nice doggie
If they did, they probably wouldn't tell you.
Try the parts classified area. Good luck.
Jerry 78 SC hotrod 02 Mini Cooper S |
Howzit,
You can find them at wheelenhancement.com, but they want $675.each (same price for 16x8). Unless you NEED the extra 1", consider 16x8's. You can expand your search by looking for either 8's or 9's. They will both accept the same size tire 245/45/16, and look the same too (same lip depth). I found a pr of 16x8's off ebay, then had them refinished by Al Reed, all for $600/pr. good luck Mike '86 coupe
