ed bates's Avatar
Slight smoke upon cold start.....
Is this normal for a 1981???????
1979 911SC (The only way to fly)
1999 740I BMW
2002 SLK320 MB
95 Surb w/26 Hallett Sportboat
Old 05-10-2004, 09:11 PM
Make Bruins Great Again
Por_sha911's Avatar
Cold weather startups will produce a little vapor from the condensation in your system. White smoke. Normal.
Warm weather you will see a small puff of smoke upon startup-a sure sign that you are running a flat 6 motor. Normal.
Bad things: smoke when you let off the go pedal, blue smoke for any period of time at startup, smoke coming from the dashboard (get a fire extinguisher fast).
p.s. there are many threads on this (the Search button is your friend)
Joe
Old 05-10-2004, 09:59 PM
