Big time oil smoke
1984 3.2 with 70K miles. Normally there is no oil smoke with this car and it does not burn oil based on checking levels, however, tonight driving home I had to slam on the brakes and just immediately after than I started laying out a smoke screen of white smoke coming out of the tail pipe. The car ran ok and the oil smoke dissipated in about 30 seconds. Coming home after that I slammed on the brakes on purpose and it repeated the same thing.
Could I have too much oil in the filler tank? Is there oil pushed somewhere by the fast stopping where it normally should not go? Or am I seeing the start of something bad?
1984 3.2 Cab (now toy) 1975 911S (old toy) Mercedes E350 W4 (snow car) 2007 911 Turbo (water and air pumper) 2012 Panamera 4S (for the wife, I swear) |
Make Bruins Great Again
White smoke? That's usually water (condensation). Grey or black is fuel. Blue is the dreaded oil.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
It was definitely oil smoke based on the smell
I noticed my 87 did that, seemed to smoke when I braked, more smoke the harder I hit the pedal. I ended up rebuilding the top end of the engine.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
normal. keep the oil level down about 1/2 way between the hi/low marks on the dipstick. oil just sloshed into the intake. hard turns can do it too.
