Hi All, have a dead speedo in my '76 Carrera, took out the sender and I'm getting continuity all the time across the terminals
I tried waving a magnet across it to no avail... Am I right in thinking that it's a goner? (Don't want to buy a new one unnecessarilly) Thanks! Warren McAllister
'76 Carrera 3.0 '02 Mercedes Benz E200K Bianchi (Road) Cannondale F800 (MTB) |
I believe the sender is a coil and it picks up the mags on the transmission and creats a small voltage like a generator. So it would read continuity.
Mike Minister of YEP 1986 targa 3.2 " RED" 1970 Little T (Wife’s car) Gruppe B # 917 |
WRONG!!! The speedometer sensor is a magnetic reed switch with normally open contacts, and the switch contacts close and open in response to the eight ceramic magnets on a carrier wheel inside the transaxle case. The factory service manual specifically says to test for eight switch closures per revolution of the ring gear!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Sounds like it's bad. You should get continuity only if you put a magnet on it to close the switch.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
sorry about the bad info and I'll be more careful
to check my info before I respond in the future
Thanks for your help everyone! - Warren
