Optima Installation
I installed an Optima red top yesterday in my '87 930. AJ USA's aluminum mounting plate fit well. One thing I thought I should mention to the board is if you purchase a battery cut off switch from out host, you do not need a longer ground strap, the factory strap will suffice.
www.pelicanparts.com/catalog/shopcart/911M/POR_911M_electr_pg11.htm#item49
Tim
'06 Cayman S
'96 993tt
'87 930 (gone, but not forgotten)
Old 05-10-2004, 08:12 AM
