-   -   How to remove Dashboard Center Face Plate? (http://forums.pelicanparts.com/porsche-911-technical-forum/162070-how-remove-dashboard-center-face-plate.html)
shillier 05-07-2004 08:21 PM
Hi,
On a '81 911 SC...
I'm trying to remove the center Dashboard Face Plate... the one that has the vent/fan controls and radio. Any tips on removing it. I would hate to damage it. I've removed the radio. I've also tried to remove the vent/fan control face, but it seems to be screwed in or something.
Any ideas, tips would be great.
Shayne
poorsha 05-07-2004 08:46 PM
Shayne.
Look under the dash and you should see that the control assembly is attahced to the front body with a bracket and a bolt into a rubber absorber thingy (am I making any sense? I hardly understand it myself).
Once you undo the bolt (10mm I think) you will have to undo all of the cables that control the vents (a bit of work but doable).
The trim panel is simply attached with 2-sided tape. Use a putty knife and carefully pry it off.
Why are you removing it?
Email me and I can send you a pic of one removed.
poorsha@shaw.ca (left Coast).
