Porsche Crest fender oil cooler as front oil cooler?
Curious if anyone has retro fitted a fender cooler and mounted in the front (in a RUF type bumper).
I have an opportunity to pick up a used Carrera cooler and was wondering if I would see a noticeable difference if I mounted it in series with my current trombone cooler.
Reason for this is budget...looking to install a purpose built cooler (Elephant) in the future.
Any comments would be appreciated. Thanks
Andy
81 911SC (BW Motorsports RUF)
Old 05-09-2004, 06:42 AM
Elombard's Avatar
I have wondered this myself. I cant see how it would hurt? I would ditch the trombone and just plumb the carrera in the bumper and then add Chucks cooler later. Might make the plumbing easier for now? I would pass on the Carera unless its cheap... alot of times you can get an aftermarket that would fit better in the front bumper for less money than a used carrera. my $.02
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-09-2004, 07:03 AM
Chuck Moreland's Avatar
I'd just take the trombone out and use the Carrera cooler (provided it is known clean and not from a blown up engine which may have deposited metal bits in it). Or get a cooler designed for center-mount.
The trombone won't add much cooling so it's hardly worth keeping. And since it connects directly to your hard lines, splicing in to connect a center mount is going to be a project. Not worth it.
The Carrera cooler can be squeezed into some front valances. But it's proportions aren't optimal. Laying on its side, its about 8 inches tall and 16 inches wide. Your bumper will accomodate a much wider cooler.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-09-2004, 09:58 AM
