Low oil temps?
Hi all,
My 71T 2.2 never seems to get very hot. Probably the highest temp I've had the car out in is maybe in the low 70's, but I've never seen the temp gauge go higher than about 160-170. It does respond to outside air temp (lower on cold days, etc.) so I think the gauge is working. Senders seem ok. Is this a problem, or am I just lucky not to have everheating problems?
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
The oil should get warm enough to vaporize contaminents (water & fuel). Normally the temp necessary to do that will be closer to 210.
If you usually see 160-170 then that's probably fine, but I wouldn't be at all surprised if your gauge or sender is not quite right or you've got a bad connection someplace.
My 87' Carrera never goes beyond 170 degrees and hits about 185 if it's been idling awhile. I even backdated the gauge/sender and get the same readings. I haven't had the car long enough to have driven it in weather above 70 degrees, however.
John |
I've tried changing the sender, but still get the same readings.
Make Bruins Great Again
You may have a oil cooler thermostat that is stuck open and it is circulating the oil too soon.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
John |
I bought it last fall right after the weather turned cool. Mine has been running anywhere from 140-185 depending on the temp outside. I'm currently checking to see why it won't go above 145-150 when the outside temp is 45-50 degrees. When its warm out, it will go up to 175-185 and stay steady.
Well I replaced the oil thermostat, and still get about the same temps, maybe a little higher, but still below 180. The oil pressure is a little lower. I'll have to see what it does in warmer weather.
Do you guys have the standard 120-300F temp gauges?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I have the standard gauge where the numbers are off to the side just out of view (in celsius).
