What should I pay to have my Weber Carbs rebuilt?
How much does it cost to have a pair of weber carbs rebuilt...........My car sounds like POP-Corn
And since i'm having SSI heat exchangers put on next week......I mineswel have my weber's rebuilt .........Up to how much does this cost?? SvK 1968 911L |
Define rebuild???
Simple tear down and replace gaskets? Or are the throttle shafts in need of work? |
I just had mine done by a very good local porsche garage. I made all the difference in world. I did the R&R and it cost $600
what differences did you notice??
(i am experiencing lots of backfiring usually when i come off the freeway) |
Mikez,
I'm not sure.... like i said they are backfiring like popcorn in a microwave...... I am not a DIY guy.....just don't want to get ripped off SvK |
Mike Z .....
What should I look for in the shafts? How can I tell what work they require SvK |
Experienced overall smoother and more responsive acceleration. Carburetor popping and exhaust backfire improved as well, HOWEVER
most of thus was probaly due to an exhaust leak found when the rebuilt carbs were tuned. If you are the cautious type we may want to do your other work and then get a good tune-up w/carb balance. If not good enough go with the carb rebuild. |
thanx mygatts
SvK |
| All times are GMT -8. The time now is 01:35 PM. |
