doozer's Avatar
Question coil over shocks vs. torsion bars - which one?
I am trying to decide between a complete coil over kit or stiffer torsion bars and adjustable spring plates - this is going on an 84 911...
Any advice as to which is a better idea and why..
Any reinforcements needed for the coil overs?
Thanks!
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 05-08-2004, 08:15 AM
ttweed's Avatar
Unless this is going to be a serious track car and you need spring rates higher than torsion bars can give you, or the ability to quickly change spring rates, I would stick with the torsion bars. It's very much more $$$ for the coilover kits. I wouldn't install them without reinforcing the shock perches, either.
Doesn't an '84 come stock with adjustable spring plates?
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 05-08-2004, 04:24 PM
doozer's Avatar
Thanks ttweed,
Yes - but I was thinking of adding the quick adjust ones with the alen screw height adjust.
Todd
Old 05-08-2004, 08:24 PM
The car is too heavy for coilovers without reinforcement to the chassis.lt works okay on a stripped tub but the body is not designed for the amount of forces put on the shock towers by coilovers.l`ve got an 84 also and l considered the coilover route,briefly,but went with the well documented upgrades of heavier t/bars,sways,bushings,adjust spring plates,sport shocks,bump steer,strut brace,etc. The car handles as expected,great.
my life begins at 150MPH
Old 05-09-2004, 12:37 PM
